Playing a simple 5th harmony
Home Forums Products Stompboxes Playing a simple 5th harmony
    • #116104
      nicocaumon
        I’ve got some simple single notes to play but I would just like to add a 5th in harmony (no delay, played at the same time) with my H9 but the h910-949 is not working well.
        Which algorithm/setting would be good ?
        Thanks
      • #155827
        bohan
          nicocaumon wrote:
          Hi, I’ve got some simple single notes to play but I would just like to add a 5th in harmony (no delay, played at the same time) with my H9 but the h910-949 is not working well. Which algorithm/setting would be good ? Thanks
          Why is H910/949 not working well? Have you turned off the delays?
          Have you tried PitchFlex algorithm?
        • #155829
          nicocaumon
            The pitched note was « dirty ».
            I’ve purchased the Diatonic and it works fine, even without delays. The mix has juste to be around 50%, not more 🙂
          • #155832
            bohan
              nicocaumon wrote:
              The pitched note was « dirty ». I’ve purchased the Diatonic and it works fine, even without delays. The mix has juste to be around 50%, not more 🙂
              If you set the Type parameter to Modern it may sound better.
              OK. I'm glad that Diatonic works for you.
