Please help me! How do I reboot the DSP 4000?
Home Forums Products Rackmount Please help me! How do I reboot the DSP 4000?
Viewing 7 reply threads
    • #106441
      Hallo everybody:-)
      I am coming from Frankfurt and have a big problem with my DSP 4000,
      when I turn on the DSP 4000 it says " an error occored"
      a long code is following….. ( it makes me cry…)
      He says:
      "Write down the code and reboot the the DSP"
      My question:  HOW DO I REBOOT THE DSP 4000
      Maybe somebody has an idea, I go crazy when I have to send my pearl away to repair.
      Thank you very much!!!!!
    • #119046
      Hi Mike
      you can try to power on the unit pressing & holding the PROGRAM key. This should force the unit to unload the last running reset that may have caused the lock-up. Subsequently you may also try a clear setup from the SETUP menu.
      best
      I
    • #119053
      Hi:-)
      Thank you so much for helping me!
      What do you mean with clear setup how can I get there? Because when I turn on it just show the error page and nothing you push reacts.
    • #119054
      I tried the programkey solution then the DSP says:
      "You want to load MUTE yes or no?"
      Ist that alright if yes means I should tell him yes?
      I pushed no because I didnt want to make a mistake
      Your idea to clear set up impossible to do because no key reacts while the page says the error occured please reboot.
      I hope so much you have an idea:-)
      Thx
      Mike
    • #130167
      Mike
      hit YES! That should make the unit boot.
      Clear setup should be available unders the SETUP key. Look for the menu with all system parameters reinitialization.
      best
      I
    • #130168
      Thank you so much! You give me hope:-)
      Ok I will press yes! I reaaly dont know what will happen after pressing it.
      At the moment the key "setup" is after I pressed it not reacting….
      Cheers:-)
    • #130169
      Hallo:-)
      You helped me very effective!!!  Thank you so much!
      It works again! I really dont know what the problem of my pearl was, but he is smiling again!
      Wow! How can I thank you for that?
      Greetz
      Michael
    • #130170
      Michael
      just send the champaign in!
      Big Smile
      There can be many different causes, like a power unstable feed, or a corrupted preset, cosmic rays……..
      glad you're up & running!
      best
      I
