Home › Forums › Products › Rackmount › PLEASE help me update Eclipse from v1.101 to version 4 – cards do not work. Also Eclipse question
September 1, 2021 at 7:00 pm #116637
Quantum7
ParticipantFirst I tried Lexar 32 Gig card that I had laying around, but to no avail. Next I looked at the recommended cards and found the closest one I could find to what was on the list – Amazon.com: SanDisk 512 MB CompactFlash Card, SDCFB-512-A10 CF Type I Card : Electronics It is a 512mb, as I couldn’t find a 256mb one. The Eclipse cannot read it, or even format it. Any help would be GREATLY appreciated.
Question – While I’m still on 1.101, is it normal that the Eclipse has only 367 patches….actually less, because some numbers are missing. Did I buy a defective unit?
September 2, 2021 at 12:51 pm #158505
Quantum7
ParticipantNo one here has any advice for me?
September 2, 2021 at 4:44 pm #158510
noodle1
ParticipantDon’t worry, the earlier versions were much different on presets/firmware. If I remember correctly the earlier v1 firmwares were picky about the capacity (256MB, for sure less than 2GB) and (FAT) format of the card. I can’t give full update instructions right this second but wanted to give a response so you’re not worried about your new Eventide unit. Search function is your friend.
Here is an earlier post from earlier in the year: https://www.eventideaudio.com/community/forum/rackmount/eclipse-300-update-issue/
I had the exact same problem. What fixed it was:
1. Format the CF card using the eclipse, not the mac.
2. Make sure the CF card is the right capacity, these days the cards are all too big so I had to find a 256MB card and that worked like a charm.
September 3, 2021 at 7:40 pm #158531
Quantum7
ParticipantThanks, everyone. I am now going to order this one from Amazon: https://www.amazon.com/256MB-Sandisk-Compact-Flash-Card/dp/B005TCYNW0/ref=sr_1_3?crid=3C9W2Q1VC5UH4&dchild=1&keywords=256mb+cf+card&qid=1630606499&sprefix=256mb%2Caps%2C170&sr=8-3
It would be nice though if someone could point to one on Amazon for me that actually worked for you. Anyone? 🙂
September 4, 2021 at 5:35 pm #158561
Quantum7
ParticipantWhich one of these might work the best? I do not know the difference of what is exactly different between these 256mb cards.
September 4, 2021 at 6:55 pm #158562
Quantum7
ParticipantIf i ultimately have to do the “serial method” would this work? Amazon.com: Sabrent USB 2.0 to Serial (9-Pin) DB-9 RS-232 Converter Cable, Prolific Chipset, – HEXNUTS – , [Windows 10/8.1/8/7/VISTA/XP, Mac OS X 10.6 and Above] 2.5 Feet (CB-DB9P) : Electronics
September 5, 2021 at 2:54 pm #158566
Can't promise anything, as your setup is beyond our control. Sandisk is a good brand (they invented the CF card, I believe). Use a new card and DO NOT format it. 512M should be OK, but nothing above 1G. Prolific is good, but see below.
If you continue to have trouble, try the serial. But be aware that there are a lot of knockoffs of Prolific, and as a result they have discontinued the drivers for the older ones. Buy a new one from a known supplier (not eBay).
You may well have problems with a unit that old (probably 20 years), and there will be limited support we can offer. If all else fails, either return to sender, or put it in for service (support@eventide.com).
September 6, 2021 at 1:13 am #158571
September 2, 2021 at 8:28 pm #158512
noodle1
ParticipantQuantum7 wrote:No one here has any advice for me?
There’s also a Plan B: the SERIAL update method. You will need Windows with a serial port or USB/serial adapter cable as I understand it.
Note v3.5 will need to be flashed first (before flashing to v4.0 firmware)
https://www.eventideaudio.com/support/downloads
I’ve heard the old units/firmware were pickier about the cards so just wanted to throw this out there!
September 5, 2021 at 6:25 pm #158569
Quantum7
Participantnickrose wrote:Can’t promise anything, as your setup is beyond our control. Sandisk is a good brand (they invented the CF card, I believe). Use a new card and DO NOT format it. 512M should be OK, but nothing above 1G. Prolific is good, but see below.
I’m trying one more card, then will try the serial cable method. If this doesn’t work, can I send it to Eventide to be fixed/updated? Thanks!
