Please recommend a good (small) single button aux switch
Home Forums Products Stompboxes Please recommend a good (small) single button aux switch
Viewing 4 reply threads
    • #113932
      joeydego
      For the H9. I’d like to control the active/bypass function with an aux switch. Thanks. (I CAN do this, right).
    • #145382
      gkellum
      Barn3's TeslaTap fits that description: http://www.barn3.com/shop/tesla-tap
      Another option would be the Boss FS-5U although it's not as small as the TeslaTap.
      And yes this is possible.  To get to the Aux Switch mappings in H9 Control, press the Pedal button in the bottom menubar and go to Aux Switch Mappings.
    • #145385
      joeydego
      Thought of something last night. Can I eliminate this external footswitch and use a button on the TC G system? The buttons I believe can send midi messages. I think I’d need to program the eventide to bypass + dsp to get the spill overs correct? Then to read the midi command from the button on the TC. Do I have this right?
    • #145386
      gkellum
      I don't know anything about the TC G system but if it can send either MIDI CC messages or even just MIDI program change messages this should work for toggling the H9 between active and bypass.
    • #145464
      cliveluis
      Although not small, i highly reccomend this, very versatile….you can use it with so many other pedals too .. so never a waste
