Plugins not appearing in Komplete Kontrol
Home Forums Products Plug-Ins Plugins not appearing in Komplete Kontrol
Viewing 8 reply threads
    • #115577
      ians
        HI
        Just bought Flanger II, Phaser II & Quadravox, licenced fine but they dont appear in Komplete Kontrol. Both the vst & au version appear in Machine however, which is odd.
        Phaser seems to crash KKs plugin scanning tool as well
        Any ideas?
        I’m on Mac, latest Mojave, btw
      • #153073
        Fender17
          Well, most of Eventide plugins is not NKS, the only one is, I guess, Blackhole. :-(((
          So, the integration wth Maschine or Komplete Kontrol is not ideal.
        • #153081
          tlongabaugh
            Hey ians-
            We're partially able to reproduce the crashing issue, and are looking into it. The plugins should work as VST/AU in Komplete Kontrol, though not with NKS integration. Are you seeing the VST/AU in Komplete Kontrol?
            -Tom
          • #153090
            ians
              Strange. I loaded KK& they were nowhere to be seen, then loaded Maschine & they appeared in the menu. So I reloaded KK & they have now appeared there as well!?
              Anyway, it seems to have sorted itself out
              THanks for the replies
              Ian
            • #153108
              ians
                Just installed Octavox, & now that’s crashing the scanning app in KK on start-up
              • #153114
                tlongabaugh
                  Hey, can you confirm for me that you have the latest iLok License Manager installed? We're still looking into the crashing problem, but it could be related to the version of iLok.
                • #153115
                  ians
                    I just checked & I have the latest ilok version, thanks
                  • #153118
                    tlongabaugh
                      Hi, can you try the actions outlined in this post and let me know if it solves your problem? https://support.native-instruments.com/hc/en-us/community/posts/360008362457/comments/360001112878
                      Additionally – if you go to Preferences->Plug-Ins and select "Rescan", does the crash still happen?
                    • #153120
                      ians
                        Strange. Now it has appeared in KK & is working fine. I haven’t done anything to try to solve it. Last night only the VST was in Maschine’s menu, but no AU. This morning they are all present & correct
