Home › Forums › Products › Stompboxes › Polyflex Volume drop
- This topic has 15 replies, 4 voices, and was last updated 1 year, 8 months ago by joecozziEventide Staff.
May 9, 2023 at 1:00 pm #171118sukeceruloParticipant
I was excited to try the new Polyflex but there is noticeable change in tone and drop in volume as soon as you engage the MANUAL FLEX. I did a back and forth with my presets with Pitch flex and there is no problem with the Pitch Flex but there was on the Poly Flex. For the Polyflex I just used an INIT program and some of the presets. The drop in volume and change in tone happened with and without my EXP pedal (Roland EV5). I thought it was the exp pedal, but I recalibrated it and the problem still happens when I use the mouse to control the Manual Flex.
May 9, 2023 at 3:42 pm #171124
Can you provide some more information about your setup? Are you going mono in/out of the H90 or are any of the input/outputs stereo?
Are the Polyflex voices panned at all? Can you also check that the Program and Preset gain levels are at unity?
May 9, 2023 at 6:57 pm #171134sukeceruloParticipant
Hi, I have mono in and mono out. My dirt pedals are a mono insert. All levels are unity gain and pan is centered. I created a new program with the POLY algo on A and the PICH algo on B. Both set to +5. I still experience same issue where once the MANUAL FLEX is activated on POLY, the volume drops and tone gets thin. I made a video but everytime I try to attach my reply doesnt go thru. Ill try to add again
May 9, 2023 at 6:59 pm #171135sukeceruloParticipant
Try to view the video here POLY FLEX PROBLEM
May 11, 2023 at 12:47 pm #171181
Appreciate the video and the extra info, I can definitely hear what you’re talking about with the volume drop but am having some trouble re-creating it myself. What happens if you use the same settings from the video with the Manual Flex knobs at 0 (pedal in heel position) but turn Auto Engage Off, and then adjust the Mix value from 0 – 100? Do you still hear just as significant of a level drop or is the level more similar between a mix of 0 and 100?
May 11, 2023 at 2:13 pm #171182sukeceruloParticipant
Thanks for the reply. When Auto Engage is set to off, the volume drops as soon as the preset un-bypassed. The drop in volume is consistent regardless of where the exp pedal is in its sweep
May 11, 2023 at 4:17 pm #171183
I can’t recreate this either. sukecerulo, if you could, can you attach the Program that’s giving you problems so we can test our pedals with that Program, please?
May 12, 2023 at 1:02 pm #171185sukeceruloParticipant
Ok, I attached the program
May 12, 2023 at 3:55 pm #171194
sorry sukecerulo, not seeing an attachment. Can you reply with it here?
May 12, 2023 at 4:03 pm #171195sukeceruloParticipant
Ok uploaded again,
May 12, 2023 at 4:12 pm #171197
Perhaps the forum interface is confusing but I don’t see an attachment here. Please email it to me at jcozzi@eventide.com
May 13, 2023 at 11:17 am #171218sukeceruloParticipant
I emailed it to you. I noticed the website was responding weird when I tried to upload stuff
May 12, 2023 at 1:32 pm #171189sukeceruloParticipant
I think I can reproduce it. PERFORM MODE: start w INIT program. Add POLYFLEX preset. It should work ok. NOW go to control assignments and change FS 1 to Tap tempo. Try exp pedal again and hear the volume drop as soon as it kicks in.
May 12, 2023 at 4:09 pm #171196
Hi sukecerulo, I followed your instructions in the video below, but I cannot reproduce the issue. Please watch it and let me know if I did something differently.
https://www.dropbox.com/s/0p29sy4pbpxqd1z/polyflex%20example.mov?dl=0
May 12, 2023 at 4:43 pm #171198sukeceruloParticipant
Thank you for the video that’s what I did, same as you. But now I couldn’t repo it again, I thought maybe it had to do with tapping the tempo and then the problem, but it was inconsistent. My program I sent you still does it for me, not sure what Im missing or whats going on. Thanks for follow thru on this, I totally love the H90, its rocking so hard and sounds wonderful. Incredible tracking too. Thank you!
May 13, 2023 at 4:14 pm #171224
Hi sukecerulo,
Thanks for sending that Program. I can reproduce the issue. Weird. Now, when I create my own version of your Program on a new INIT Program, putting PolyFlex in A and PitchFlex in B, I get consistent levels. I use the stock “Up P5th Flex” preset just like in your Program. I have no idea why one works and the other doesn’t. All I can recommend to do is create a new version of what you’re trying to do and things should be fine.
