May 5, 2012 at 3:24 pm #108719
Hi i just upgraded to PTHDX and the plugin that's in use in all my session is the Eventide Reverb from the Anthology 2 bundle.
I need to match the Reverb in the h8000 to recall some of my mix
Which Patch do i need to start with the H8000 ?
See the attached Pix
Thanks
Francois
May 7, 2012 at 3:39 pm #123414
While the plugin was derived from the H8000 presets, there is no direct equivalent.
Hopefully one of our users has been in the same position and can offer some help.
There are others here who will know more than me, so I'll ask around.
May 7, 2012 at 6:27 pm #123415
Thanks you for looking into this
Francois
May 7, 2012 at 10:03 pm #134512
Hi tarafran,
As Nick says, there's not an exact match in the H8000 for the Eventide Reverb plug-in. However, what algorithm in Reverb are you using? I might be able to steer you as close as possible.
Dan
May 8, 2012 at 3:00 am #134513
Hi Dan ,Thanks for looking into it ,
I have the link to the plugin screenshot on the first post.
Francois
May 24, 2012 at 6:41 pm #134562
any update on porting the reverb hall to the h8000fw ,thanks
francois
May 31, 2012 at 10:06 pm #134591
We sat down with an H7600 and a copy of Anthology reverb configured to your plugin settings and a/b'd some H7600 presets against your plugin settings. We were able to get a sound that gets pretty close. We should be able to dump the preset and upload it in the very near future.
June 1, 2012 at 2:34 pm #134593
awesome guys
thanks
July 7, 2012 at 10:31 am #134664
Any progress on the upload ?
Thanks
July 9, 2012 at 5:26 pm #134667
Sorry about this, it's been on my to-do list for the past month… I have the unit containing the preset with me, now I just need to find it. I'll try to get it up by the end of the day, if not then the next few days.
July 10, 2012 at 6:40 pm #134673
Attached is the vsig file. This should get you pretty close.
Thanks,
Nikhil
July 11, 2012 at 2:16 am #134675
Thanks Nikhil
I copied the file to the memory card ,but i do not see it on the H8000 menu.
what I am I missing?
Thanks
July 11, 2012 at 3:21 pm #134678
Load the file in vsig, then connect your H8000 to your computer and upload the vsig patch to your H8000 from within vsig.
July 11, 2012 at 6:28 pm #134681
any Vsig for mac?
all the link I tried are dead
When I tried the beta on my window partition,the H8000 hangs on recieving the file
Thanks
francois
July 12, 2012 at 6:30 pm #134683
Let's try something else… I've linked a zipped folder containing a binary file of the preset. Extract the folder (on Mac, this should be as simple as double-clicking), place the folder onto your memory card, and you should be able to load the preset on your H8000 from the card. Let me know if that doesn't work.
Thanks,
Nikhil
July 12, 2012 at 10:25 pm #134684
You are the man
Thanks
