Possible to tempo sync Space to Korg SQ-1?
Home Forums Products Stompboxes Possible to tempo sync Space to Korg SQ-1?
Viewing 3 reply threads
    • #114579
      Hi, I’m driving a small synth setup with a SQ-1 and was wondering if there was a way to make them talk to each other. Specifically I want the Space to receive clock from the SQ-1. SQ-1 has a sync-out which is a 5V 15 ms click track, but Space only takes MIDI in. Maybe anybody knows a workaround? Thanks 🙂
    • #148340
      bohan
        balthasar wrote:
        Hi, I'm driving a small synth setup with a SQ-1 and was wondering if there was a way to make them talk to each other. Specifically I want the Space to receive clock from the SQ-1. SQ-1 has a sync-out which is a 5V 15 ms click track, but Space only takes MIDI in. Maybe anybody knows a workaround? Thanks 🙂
        There must be some sort of cable/adapter that sends MIDI from SQ-1 jack to 5-pin normal MIDI jack.
        https://www.ebay.com/itm/5-Pin-DIN-Male-Cable-5-Pin-Din-MIDI-Plug-To-3-5mm-1-8in-TRS-Stereo-Male-Jack/
        https://www.ebay.com/i/253387136698?chn=ps
      • #148341
        bohan
          Also make sure your turn on CLK IN on your Space
        • #148351
          Thanks! Sync’ing through MIDI indeed works
