Power converter or Plug adapter for TimeFactor
Home Forums Products Stompboxes Power converter or Plug adapter for TimeFactor
Viewing 3 reply threads
    • #106987
      vahe
      If I buy a TimeFactor in the USA, will I need a power converter or just a simple plug adapter to work in Europe ?
    • #120219
      badmelonfarmer
      I do not know what specification PSU is supplied with the TimeFactor in the US.
      Most of Europe is bewteen 220-240 volts AC, so the PSU would need to be ok to run at these voltages even with an adapter.
      It should tell you on the actual adapter what input voltages it will work with.
      Alternately you could use a 1spot with the L6 adapter, they work worldwide.
      Cheers
      BMF
    • #120224
      Dreamsy
      If you buy the Factor outside of Europe, then you'll need to buy a new adapter. Plug adapter won't workd as the input voltage for the US version is 110V.
      At least it was true six month ago when I moved back to Europe from the US.
    • #120227
      You can get a range of national power adaptors from the Eventide Store…
