Home › Forums › Products › Stompboxes › Power Factor 2
September 16, 2013 at 5:25 pm #111096
I just read the spec and the power factor 2 only comes with three eventide power cables. Shouldn't 4 come with the unit
September 17, 2013 at 1:09 am #124808
You should be able to get more from any guitar shop selling pedals. I'm more interested in when units will hit the UK, including the "mounting kit", which I hope is a rackmount kit.
September 17, 2013 at 3:07 am #124810
The power cables are RCA to 5.5/2.5mm centre positive DC-plug. not readily available around where I live. Not at GC either. Just saying, if it is made to power 4 factor pedals it should come with 4 cables to do so.
September 17, 2013 at 6:52 pm #135645
We made a mistake in the product description (probably due to copy and pasting some sections of the original PowerFactor's product description). The PowerFactor 2 does in fact come with 4 cables. Thanks for pointing out the mistake.
September 17, 2013 at 7:07 pm #135646
Great
Thanks, Keep up the great work,u guys/gals are the best
September 17, 2013 at 8:19 pm #135647
Voltage selector is 230v/115v. My utility voltage ranges from 232v-249v. Am I to expect any issues when using the 230v setting?
September 18, 2013 at 3:48 pm #135656
Your voltage range will be OK, but the power supply may run a little warmer at the high end.
