Power Factor Power Supply??
Home Forums Products Stompboxes Power Factor Power Supply??
Viewing 4 reply threads
    • #112199
      jm197
      I am a bit confused on the Powerfacor .  It states it will run 4 Eventide stompboxes but has 2 outputs that are 9/12v at 400mah and 2 outlets that are 12v only at 400mah. I have a Space and a timefactor both stating power requirements of 9v 1200mah and a H9 with a power requirement of 9v 500mah.  Can someone help?
    • #127248
      The 1200mA is an overstatement (sorry). All of them will be happy with 400-500mA at 9V, or, in the case of a well regulated supply like a Powerfactor, will use a lower current at 12V.
    • #127249
      jm197
      Hello, Thanks for the reply.  So it will be ok to run the boxes on the 12V outlet even though they are 9V?  Thanks
    • #137876
      jm197:
      At the risk of repetition – as long as it is the well regulated output of the PowerFactor. A generic 12V unit may cause damage.
    • #137878
      jm197
      Ok Thanks. I'm sorry to ask again but I wasn't sure I understood.  This clears it up.  Thanks again.
