power roland FC50 Midi pedal with Eclipse remote power in?Canan
Home Forums Products Rackmount power roland FC50 Midi pedal with Eclipse remote power in?Canan
Viewing 5 reply threads
    • #107567
      bert lams
      I'd like to power my 9v DC Midi pedal (a Roland FC 50) from the Eventide Remote Power out.
      Does anyone out there know what cable I need to do this?
    • #121426
      You would need a 7 pin DIN cable.
    • #121429
      bert lams
      I meant to ask: how to send DC power from the Eclipse (using the 'remote power in' on the back panel of the Eclipse). My FC 50 Midi pedal runs on batteries, or on a wall wart, but I'd prefer to power it up from the Eclipse. So I'm not talking about sending Midi information, but about sending 9v DC from the Eclipse to the FC 50 so I don't have to use batteries or wallwart for the FC 50.
      Thanks for your patient replies!
    • #132612
      I see (I think).
      The Eclipse won't generate the power (too many possible requirements) – you have to plug a wallwart into the socket by the MIDI socket – then it sends it down the cable. It's mainly used to connect to pedalboards with a single cable.
    • #121451
      sshogrin
      Your FC 50 has a 5 pin MIDI OUT, you'll have to use something like the Rocktron 7 Pin to 5 pin MIDI cable and either find or make an adapter for the 5 pin "power jack" to plug into the FC 50. Use your wal wart power supply to plug into the back of the Eclipse.
    • #121453
      bert lams
      Thanks !
