Power Supply for Timefactor
Home Forums Products Stompboxes Power Supply for Timefactor
    • #116319
      npx
      Hello from Germany,
      9V and 1500 mA should be okay as I have seen in some comments.
      But a question regarding the polarity of the connector: in the middle + and on the outside ring –
      Is this correct?
      Best regards
      Norbert
    • #156962
      bohan
      npx wrote:
      Hello from Germany,
      Is this correct?
      Yes correct. The jack should be 5.5/2.5 mm center positive.
      However, 9V/500ma should be good enough. You don't need 1500mA.
    • #156967
      npx
      Thank you for your kind help!
      Best regards
      Norbert
