power supply tolerance
Home Forums Products Stompboxes power supply tolerance
Viewing 3 reply threads
    • #111245
      rdnzl
      Hi there,
      Is it okay to use a 9V 1.2A power supply to power a H9? That's more than twice what is needed…
      I have ordered a replacement but hasn't arrived yet…
      Kind Regards
    • #125089
      Mcdookus
      You can have more milliamps but not less. That supply will be fine. Just make sure the polarity is correct. The h9 needs center positive and most power supplies I've seen are centre negative. You can buy an adapter to change the polarities. I had to buy a current doubler and an adapter to power the h9 with a Carl Martin powerblock
    • #125090
      Do note that while many power supplies will be fine, some may cause damage that will not be covered by warranty.
      Where possible use an Eventide approved supply (see Web Site and Eventide Store). Otherwise, there is an element of risk.
    • #125091
      rdnzl
      I am actually using the space power supply…
      Thanks for the feedback.
