Powerfactor 2 and the GigRig G2
Home › Forums › Products › Stompboxes › Powerfactor 2 and the GigRig G2
Viewing 5 reply threads
    • #114566
      VmusicV
         I’m interested in the Powerfactor 2 because I just bought a Temple Audio pedal board, and it’s designed to work nicely with that board………….however………. I have a GigRig G2, which per the manual requires 9v DC@500mA [page 35].
        Has anyone used a Powerfactor 2 to power a GigRig G2?
        Thanks,
        Alex
      • #148269
        camn
          It looks to me like you would be under-specced with that combo… although it certainly might WORK, and be totally fine.
          Alternate suggestions:
          The new Truetone CS-6 should DEFINATELY fit under a Templeboard…. if it has enough juice for your setup.
          I (and others) use a CS-7 with my H9, and it is flawless. . . and would PROBABLY be doable on a templboard….but maybe not.
          e.g: https://www.thegearpage.net/board/index.php?threads/temple-board-w-truetone-cs-7-power-supply.1893910/
          For reference: Heights:
          Powerfactor: 1.75″
          Cs-6: 1.22″
          CS-7: 2″
        • #148273
          VmusicV
            The CS 12 is just shy of 2″
          • #148283
            Tomtama
              I highly recommend the Strymon Zuma. It fits perfectly under my Temple Audio board and powers high current pedals like my Boss ES-8, two H9s, an Elektron Analog Drive, and several other pedals without breaking a sweat.
              • #148284
                VmusicV
                  Thank You – I love it. Zuma provides 500mA, which the GigRig G2 requires, so it should work. I saw Styrmon came out with a Zuma low profile, but sadly it less power outputs.
                  Out of curiosity, how did you mount the Zuma under the board, did you mount it using the plates they have for the pedals? ….OR….. did you use something else like QuickLock or Velcro?
                • #148285
                  Tomtama
                    I used one medium Temple quick mount plate to mount it under the board.
                  • #148291
                    bohan
                      Zuma was good, but now I would recommend our new PowerMax. It has larger current and flexible voltage options, and it's less expensive.
                  • #148293
                    Tomtama
                      That looks like a very nice power supply. If the OP can wait until April it looks like a great choice.
                    • #148299
                      VmusicV
                        Too few outlets…….. but it does have some nice features 1) slim profile which is needed for Temple Audio Boards 2) USB connector 3) pass through AC outlet – but wait until April, really?
