Just added an H9 to my board but so far I’ve had to use the supplied power plug because none of the Vodoo Labs cables that came with the brick (Mondo supply) will actually fit in the H9’s power connector. They look almost exactly the same, except I think the outer casing of the plug part is just a little too thick. Anyone have a solution/source for a cable that will work?
