Home › Forums › Products › Stompboxes › powering the H9 with Voodoo Pedal Power 2+
July 15, 2014 at 3:45 am #111791rammersMember
Hi, is it possible to power the H9 with a voodoo pedal power 2+?
July 15, 2014 at 3:36 pm #126344
We can only recommend our supplied power supplies. You should contact Voodoo and ask them what they think.
July 16, 2014 at 6:56 am #126345thatsrayorMember
The H9 requires 9VDC @ min 500ma to run, so it doesn't look like that power supply will do it. It will also work with 12VDC @ 400ma (it's been stated on this forum several times, and I believe the PowerFactor runs at 12V).
July 16, 2014 at 7:34 am #126346badmelonfarmerParticipant
Correct PowerFactor runs pedals at 12v DC
July 23, 2014 at 12:29 pm #137054jbprioulMember
It doesn't work with my PP2+.
I bought a Iso5, Voodoo Lab website mentionned that i works, I'll tell you.
July 23, 2014 at 6:39 pm #126384joeydegoParticipant
I couldn't make it work reliably with mine. Back to the supplied power supply.
July 24, 2014 at 2:46 pm #126386pauliusmmMember
Is it better to use 12V or 9V? Some pedals work better with 12 V. Is there a difference for h9?
July 24, 2014 at 2:50 pm #137061
H9 will work with either. It uses less current on 12V.
But, please note the following:
1) Any damage caused by unapproved power supplies will not be covered by warranty.
2) A 12V supply must be regulated. An unregulated supply may put out a higher voltage that can cause damage.
July 24, 2014 at 9:04 pm #137067jbprioulMember
It works on my Voodoo Lab Iso5, 12vdc output (300mA) with 2.5mm Reverse Polarity (Center Positive) Barrel Cable.
