Powering Timefactor
Home Forums Products Stompboxes Powering Timefactor
Viewing 3 reply threads
    • #107937
      neldom
      Does anyone know if the Voodoo Labs Pedal Power II will power the Timefactor?
      It's not the II plus, just the II.
      Thanks
    • #122276
      parsky1
      I would post your question in the Voodoo Labs forum.  They are pretty fast about getting back to you.
      I know you can on a PP2+ with the current doubler cable plus the red plug cable with outputs 5 and 6 switches set away from "normal"
    • #122278
      BenoitD
      I found on this forum (sorry cannot find where) that such an association was not adviced by both Eventide and Voodoo Lab. I cannot explain why.
      I am a beginner in Power units, I am looking for a good one (cheaper than the Powerfactor if possible) and I found this video:
      [View:http://www.youtube.com/watch?v=io5pFtrSKn4&feature=player_embedded:550:0%5D
      It seems to work, but I would like to see it on the long term. Does this power unit will become a heat or will it works?
      I don't have enough technical knowledge to have a position.
      Hope it helps.
    • #122279
      BenoitD
      In addition to my previous post, I found this thread :
      http://forum.eventide.com/cs/forums/p/5471/27516.aspx#27516
      But in many others I found Eventide doesn't recommend the use of any other power supply than the supplied one.
