Home › Forums › Products › Stompboxes › Pre/Post with 2 H9s and one amp fx loop
December 13, 2015 at 4:54 pm #141810
Not quite sure what you mean. If you are thinking of having 2 (PRE) in series before the amp, and 2 (POST) in series in the effect loop, that will be no problem.
There might be some issues with a parallel effects loop, but that is the nature of such things when used with moere than one effect.
December 13, 2015 at 4:58 pm #141811timmyoMember
I told you I was confused 😉
What I’m wondering is, can you hook up a pair of H9s in to an amps series FX loop and have (say) H9#1’s patch tell it to be pre, and H9#2’s patch tell *it* to be post ?
December 13, 2015 at 4:59 pm #113090timmyoMember
Hi there,
I’ve got myself a bit confused about this, (and I’m having to theorise as my H9s have been delayed from my supplier – doh)
I have seen that it is possible to set up an H9 so that it is pre/post the amps front end on a per-patch basis.
Is it at all possible to connect things so that each of 2 H9s works that way? Or not?
thanks
December 13, 2015 at 7:28 pm #141812
We're all confused …
But, the answer to your question is – YES.
You have to tell the unit if you want to be in PRE/POST mode, but after that, you can set PRE or POST on a preset by preset basis.
December 13, 2015 at 8:03 pm #141813timmyoMember
Yes sorry I know I’m not explaining it very well.
How would the connections go then for the 2 units? I’ve seen the onstructions for getting 1 H9 in to a loop so it can be selected pre/post but what connects to where when there are 2 H9s in play?
thanks for your patience
Tim
December 13, 2015 at 8:21 pm #141814
I think you would connect channel 1 in series (second input 1 to first output 1), and channel 2 in series (second input 2 to first output 2).
December 13, 2015 at 8:23 pm #141815timmyoMember
Brilliant, thank you
