Preset change with midi
Home › Forums › Products › Stompboxes › Preset change with midi
    • #107080
      Can you use a midi footcontroller to call up a preset but the preset when it comes up is in the off position so you then can manually turn it on when needed?  For example I hit my midi footcontroller on preset #4 which calls for preset #18-1 to come up on my Timefactor but I want the effect to just be on standby till its needed, hope that makes sense.
    • #120407
        Only if you have one of the more sophisticated controllers which is capable of sending multiple messages with one press – for example, it would send a program change to load, followed by a CC to bypass. Most will not do this.
      • #120408
        The Gordius Little Giant MIDI switchers and module can- they're worth every penny, but they sure do cost a lot of pennies.
