Home › Forums › Products › Stompboxes › Preset changing with a boss es-8 usind midi comands
July 23, 2018 at 2:24 pm #114852Ramil7rodriguezMember
I have an h9 max and want to buy pedal switcher. I’m considerind the boss es-8 because of the midi capability. I’m wondering if I’ll be able to make presets on the switcher that recall presets on the h9 so that I can change presets on the H9 when I select a preset on the switcher.
July 23, 2018 at 7:24 pm #149787Ramil7rodriguez wrote:I have an h9 max and want to buy pedal switcher. I'm considerind the boss es-8 because of the midi capability. I'm wondering if I'll be able to make presets on the switcher that recall presets on the h9 so that I can change presets on the H9 when I select a preset on the switcher.
Of course you can. What you need to do is to assign MIDI PC numbers to the presets on the switcher. So you can recall any presets (1-99) on the H9.
July 23, 2018 at 7:29 pm #149788Ramil7rodriguezMember
Thanks. I need just received the H9 and I want to buy the switcher and wanted to make sure before I buy it. I’ll orther it today then. Thanks again.
July 24, 2018 at 9:27 am #149794banstaParticipant
I use a Boss ES5 (a little brother of the Boss ES8) to control 2 x H9. It works fabulous! Even a volume pedal is connected to the Boss ES5 and sends MIDI CC to the H9, so that I don’t need to have it in the signal path. BPMs settings and the amp channel switching are controlled by BOSS ES 5 es well.
Ramil7rodriguez wrote:I have an h9 max and want to buy pedal switcher. I’m considerind the boss es-8 because of the midi capability. I’m wondering if I’ll be able to make presets on the switcher that recall presets on the h9 so that I can change presets on the H9 when I select a preset on the switcher. -
July 28, 2018 at 8:47 am #149809neneParticipant
Can a es-5/es-8 store the selected H9 also in its patch memory?
July 28, 2018 at 3:45 pm #149812nene wrote:Can a es-5/es-8 store the selected H9 also in its patch memory?
I'm not sure what you are asking. Are you asking the same question as the original poster's?
July 31, 2018 at 6:09 am #149828banstaParticipant
Hey, the H9-Patches remains stored on H9, but you can save in every patch on ES5/ES8 up to 8 MIDI commands to select a needed patch on H9.
