Home › Forums › Products › Stompboxes › Preset list with Presets saved in Bypass
March 11, 2014 at 9:01 am #111449bucketbotParticipant
I want to make a preset list with all the preset in bypass mode so I can transfer that list to the pedal, however I can't see a way to do this.
The only way to do it seems to be to transfer the list to the pedal & then select each preset in turn on the H9 , switch it the preset to bypass & then re- save on the H9 itself.
March 11, 2014 at 1:58 pm #125527gkellumParticipant
Hm. You might be right about this. We'll look into it…
May 11, 2014 at 7:55 am #125906bucketbotParticipant
Any result on thus as it still seems to be the case.
May 12, 2014 at 4:04 pm #136622gkellumParticipant
Hey, we're looking at it now. This might go into the next release if we don't run into any unexpected difficulties. So, you're using MIDI program change messages to load the presets on your H9?
May 12, 2014 at 4:12 pm #136623bucketbotParticipant
Yep! I use the G System to select H9 presets & channels on my amps.
May 15, 2014 at 5:33 pm #136663gkellumParticipant
The latest desktop builds of H9 Control — v1.5.3 — will let you save presets in a preset list in bypass and download the preset list to the H9 in a way that preserves their bypass state. We submitted a new iOS build with this feature as well to Apple, but it usually takes them a week to approve things.
You can download the installers for H9 Control v1.5.3 here:
http://eventide.com/AudioDivision/Support/Stompboxes/H9.aspx
May 20, 2014 at 4:28 pm #136676bucketbotParticipant
Yep! Have it now on iPad. Tried it & it works great!
