Presets Disappeared
Home Forums Products Plug-Ins Presets Disappeared
Viewing 3 reply threads
    • #115113
      andrewcraven
      I moved around some of my ProTools files and folders to consolidate different projects and I think I may have moved my plugins folder in the process. When I pull up ProTools projects now I can access the plugins but all the presets are gone.  When I open the Eventide folder on my PC the presets are listed as .tide files but when I try to load these presets within the plugin in ProTools it says there are no .tide files in that folder.  What can be done to get these presets back?
    • #150849
      tlongabaugh
      Hi, I would do a fresh install of the Eventide plugins, and see if that fixes your issue.
    • #150850
      andrewcraven
      Thank you for your response. I wondered if that might be the solution but I’m uncertain on how to do that.  I have the eventide subscription through gobbler.
    • #150851
      tlongabaugh
      There should be an option in the Gobbler client to "Uninstall All". Click that, and then install again from the client afterwards.
