Printing Effects
Home Forums Products Rackmount Printing Effects
    • #107138
      Lucin Niega
      Hello All,
      I'm using the H8000FW with beta 5.5 asio drivers in Sonar 8.5. I've recorded all the tracks into sonar dry. I want to be able to go back and print effects as needed. Is there a way I can accomplish this through the routing utility? I imagine I could run out of the unit and back in via AES. Is there an easier way to do this? Internally maybe?
    • #120521
      I think you probably have to talk to Mr Sonar.
      You certainly can go in and out of the unit with AES, and this can be controlled with the routing utility or from the front panel.  Whether this would do what you want is not really in our hands. Sorry.
    • #120524
      Lucin Niega
      I figured as much, but I was really hopping to hear from any Sonar users on the forum, if there are any. lol
