- This topic has 5 replies, 3 voices, and was last updated 2 years, 11 months ago by SonikStrike.
October 28, 2021 at 3:43 pm #159848rskaudioParticipant
Hey there,
Just checking if this is measured/documented somewhere before I start testing it myself. I finally got an extra set of DSUBs wired to my patchbay and was going to start using the H9K Analog channels for extra inserts. Anyone have the ms latency for the various sample rates with a Thru chain?
October 28, 2021 at 4:02 pm #159849
We just added a section to the manual that includes information about this that should be useful for you: https://cdn.eventideaudio.com/manuals/h9000/content/setup/DAWLatencyCompensation.html
October 28, 2021 at 7:33 pm #159881rskaudioParticipant
I measured it at all the sample rates supported in PT and got:
44.1k – .84 ms
48k – .77 ms
88.2k- 1.93ms
96k- 1.78ms
This was using the method described in the link, all values rounded to two digits in case anyone else is looking to program those in.
October 29, 2021 at 1:18 pm #159887rskaudioParticipant
They certainly are incorrect and if you could delete that post that would be lovely.
That was the latency without the AD/DA just through the machine and back. Facepalm.
So much for that being a diversion to mixing, will be back to that once I get the patchbay sorted.
October 30, 2021 at 4:35 pm #159898rskaudioParticipant
All right, so redid these with the XLR Analog I/O. I have a screenshot attached below showing the routing, HW Insert using the Direct I/O on the H9k then routing into a second channel and all times are the closest I could get in the I/O HW Insert Delay Tabs.
Let me know if anyone catches a step I missed, it’s noticeably quicker than using the THRU processing blocks which seems to make sense for me but I certainly could have missed something.
This is with a HD Native card in PT Ultimate
44.1k – .22 ms
48k – .20 ms
88.2k- .55ms
96k- .51ms
January 23, 2022 at 10:30 pm #161786SonikStrikeParticipant
I measured as Inserts the AES i/o and the Pro Tools Expansion Card and the Expansion Card has way bigger Latency that the AES i/o
