problem: ADAT connection to H8000FW
Home Forums Products Rackmount problem: ADAT connection to H8000FW
Viewing 3 reply threads
    • #106542
      hummingway
      I'm trying to hook up an Eventide H8000FW to the ADATs on a TC Electronics Studio Konnekt 48. The ADAT locks on both units but I can't see any input at the H8000FW. I have the metering set to input and I've set routing to 8 ADAT A,B. In Nuendo I've set up groups for each of the adat channel io. I then put the group on a send. I can't tell if the Konnekt is actually sending anything or not.  Has anyone had any experience with this? I just got the 8000 and it looks like I've got some work to do! I'd love to be able to use the firewire from both at the same time but I guess that's another thread.
      Thanks, Greg.
      http://www.gregmartin.name/
    • #119271
      Can you plug the ADAT from the TC into something else to see if it is sending anything ?
      Using the factory routing you mention should make the ADAT show up on the input meters.
    • #119273
      hummingway
      I tried it on another TC product and I'm not seeing anything on the ADAT so I'm guessing that what's I need to solve first. Thanks.
    • #119274
      hummingway
      Problem solved. I had a setting wrong in the TC Control panel. Thanks for your help. Now on the fun stuff!
