Home › Forums › Products › Stompboxes › Problem installing firmware h90
- This topic has 33 replies, 13 voices, and was last updated 11 months, 3 weeks ago by
Eventide Staff.
November 26, 2023 at 1:21 pm #176135
<p style=”text-align: right;”>Hello, I did a search for this and didn’t find anything. I just updated H90 Control to version 1.7etc and proceeded to download the new firmware. I pressed Install and a window comes up saying “Installing Updates…Waiting for H90 mount”. It has been doing this for over 20 minutes so clearly something is wrong. Does anyone have any advice? USB seems to be working since the H90 appeared as a connected device in H90 Control. I am using Mac OS Ventura 13.5.</p>
Thank youAttachments:
November 26, 2023 at 2:21 pm #176138
Problem is solved. I am just going to post here what happened in case anyone else has this issue..
I had to do a factory reset of the device and then it allowed the firmware to download and transfer from the computer to the H90. However, during the firmware update process (firmware transfer to device from my computer), it said that 2 files were not updated or something to that effect. When I turned on the H90 pedal it got stuck in the boot up process and there was a line at the bottom of the device screen saying “E2:/install/myserialnumber-h90-1.6.11.6.bam bad file…”. I don’t know if it said anything after “file” because there is not enough room on the screen. Also every light got lit up on the pedal and stayed lit. I tried to perform a factory reset but still would get the same message and situation. H90 Control also would not recognize that my device was connected. Tried the factory reset a couple of times and same result. So at this point I was fearing that I had $900 brick with Xmas lights. Next I went back to H90 control and clicked on the sandwich menu icon and selected “H90 Recovery”. It told me to enter recovery mode by booting up the pedal while holding down the Select, Perform, and Quick Knob 1 buttons simultaneously. I did this and the H90 screen booted up in recovery mode. The screen said H90 Recovery v1.01. It just sat there doing nothing. I went back to H90 Control and my device seemed to be recognized and I re-installed the firmware. Again nothing happened so I did the firmware installation again, and this time it took. Everything is back to being functional. Not sure why this was such an arduous process with mutliple attempts for the download to get into the device correctly but after changing my pants I am happy again.
November 27, 2023 at 12:36 pm #176179
Sorry for the update issues you were having and glad to hear that you were able to resolve this.
To clarify for other users, it is not necessary or recommended to factory reset your H90 if you are having update issues. If the initial update fails, you can use Recovery Mode to try the update again. Instructions can be found here: https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/appendix/startup.html#recovery-mode
If you still cannot update using Recovery Mode, contact support@eventide.com.
February 21, 2024 at 4:50 pm #178405
Ya, this just happened to me, this really should not be happening for something that costs this much money.
February 21, 2024 at 4:56 pm #178406
I tried Recovery, When I clicked on Recovery in the App, it says error opening midi port, then gives me instructions to do what I just did. Very disappointing.
February 22, 2024 at 9:38 am #178412
Sorry to hear you are having issues. Are you running a DAW or another application that uses MIDI? That may be why you are seeing that error message.
Are you using Mac or Windows?
February 29, 2024 at 4:28 pm #178612
I semm to be in the same position. Stuck in “Waiting for H90 mount”, recovery Mode doesn’t help so far, tried 10 Times already.
February 29, 2024 at 4:37 pm #178615
Sorry to hear you are having issues. I see you have submitted a support ticket, we can help you troubleshoot this there.
September 16, 2024 at 4:40 pm #184807
i have exactly this problem.
h90 controll 1.7.11 (Mac)
h90 firmware (software) = 1.5.6.161
I can’t see my h90 in my control application on my MacBook pro
after loading in recovery mode… I can see it, and I can connect.
but first: it asks me for a Code I don’t have, and refers to the screen of my h90 ( which is in recovery mode and doesn’t show a code)
and sometimes it does connect….. I have a midi error (not midi port h90 found)
and
September 16, 2024 at 5:08 pm #184808
Sorry for the issues you are having. It is not quite clear what is happening, it sounds like you may be performing the Bluetooth connection steps.
Please email support@eventideaudio.com and we can help you further there.
December 7, 2024 at 1:21 pm #186754
Hello.
Any news concerning this Update problem ?Attachments:
You must be logged in to view attached files.-
December 9, 2024 at 8:27 am #186763
It is not clear what the issue you are having is. Did you attempt the update and it is stuck on this screen?
Please email support@eventideaudio.com with more information about the issue and we can help you further there.
December 9, 2024 at 8:53 am #186765
I can’t update my H90 pedal, to the last firmware. Impossilbe.
I stuck on this page for One hour.
December 9, 2024 at 8:54 am #186766
And yes, I attempt the update and it is stuck on this screen 🙂
I already send Two or Threee message about this issue, and i always have one : “we are on IT'”
December 9, 2024 at 9:05 am #186767
Ok, thanks for the information. Our offices are closed over the weekend, but someone will get back to you soon.
I would suggest trying the recovery mode update procedure: https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/appendix/startup.html#recovery-mode
December 9, 2024 at 9:20 am #186768
So i made the D.1. Recovery Mode¶ and the D2 Clear Current State, but nothing change
December 23, 2024 at 7:17 am #187170
Hiya Team,
Sharing my experiences here as I’m feeling a little confused by the advice I have had to date and not had any contact from support since 19 Dec.
– Brand new H90 Dark was purchased last week, pedal powered on and connected to directly to mac via Eventide supplied USB cable.
– Pedal registered to user account, current version of Control app dowloaded 1.8.16
– Control app launched.
– Pedal added to Control app.
– Prompted to download latest firmware 1.9.8
– Followed prompts to download / install firmware.
– Materials appear to download, pedal then gets stuck in WAITING TO MOUNT mode.
Repeated multiple times same outcome, locked up in WAITING TO MOUNT mode.
Once pedal locks in WAITING TO MOUNT the only way to use it is to remove the power and reboot.
Im on Mac M2 Pro, running Sequoia 15.1.1
By the looks of this thread this seems to be a known bug, over to Eventide for comment and support please!
(….yes Eventide I’ve raised a ticket and have had no response to two emails since 19 Dec).
Thank you!
December 23, 2024 at 9:03 am #187171
Sorry for the issues you are having. Some of our staff has been out of the office for the holidays and I think that is the reason your ticket has not been answered.
I have located your support ticket and will help you troubleshoot the issue further there.
December 23, 2024 at 5:42 pm #187177
Having a very similar problem here too with my H90 Dark as well.
Pedal Connected to IPADOS and telling me there is an update.
Disconnect everything and bring ii to the window 11 PC – Connect Download Mount. Seem to have successfully updated.
Bring the pedal back to the desk connect it to the IPAD . IPAD keep stating that there is an UPDATE. Did it twice. same result.
December 24, 2024 at 10:06 am #187184
Are you using the latest version of H90 Control on the iPad? That is version 1.8.16.
Does the problem persist after restarting the iPad?
You can also try deleting the H90 from H90 Control by clicking the “X” button, and then adding it again by clicking “Add Device” in the top right corner of the app.
December 24, 2024 at 11:07 am #187185
No worries, these things happen and it take a while to hammer out all the issues on various platforms. I do appreciate the quick reply , this pedal is simply fantastic .
Latest IPADOS Version of the H90 app installed.
Deleting and re-adding the device fixed it.
Thanks again and Happy holidays to you and your family. 🙂
December 24, 2024 at 11:17 am #187186
Good to hear! Thanks for reporting back.
December 24, 2024 at 12:51 am #187181
I encountered the same problem with my pedal when I tried to update it via my Mac. I took an old Surface Pro I had at home, connected it with a USB-C to USB-C cable (since that’s the only port on this tablet), downloaded the app, and the update went through successfully.
December 29, 2024 at 1:44 am #187230
I have tried all the solutions introduced here.
I attempted updating from recovery mode, a normal update, changing cables, disabling antivirus firewall, and more, but I still cannot update the firmware!When I try to update in recovery mode, the screen freezes at “Waiting for H90 mount.”
When attempting a normal update, the screen gets stuck with the double-arrow icon displayed.The device is recognized as “H90 Pedal” on my desktop, so it seems to be detected.
I bought this for a live performance, but the event is approaching, and I’m running out of time, so I’m very anxious.Will performing a factory reset possibly allow me to successfully update?
December 29, 2024 at 5:07 am #187231
Hello. What do you use to make this ?
Here my solution to this after a lot of research :
Use Recovery Mode:https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/appendix/startup.html#recovery-mode
Make sure you are not using a USB hub.
Make sure there are no other USB or MIDI devices attached to your computer.Try a different USB cable
Try a different USB port.try an USB-C to USB-C cable
Make sure no other programs are running.
Make sure antivirus or firewall programs are not interfering with the update.10. Try a different computer, or device.
For information, I never can do the last update from my MacMini. And it’s simply works at the first try in an old Surface Pro, with an USB-C to USB-C cable 🙂
December 29, 2024 at 10:51 am #187233
I was able to resolve the issue by using an older PC (Mac OS Monterey).
On the latest OS, the update would freeze during the process. However, when I tried updating using an old M1 Mac Mini that I hadn’t been using, I got a message saying, “H90 Control is trying to access a file on a removable volume,” and the update completed successfully.
On Mac OS Sequoia 15.2, I had already granted H90 Control permission under the system’s “Full Disk Access” settings, but since this message didn’t appear, the update never completed no matter how long I waited.
July 12, 2025 at 8:48 pm #190911
Eventide H90 taking a long time to update. The following message appears: Waiting for the H90 restart. This may take several minutes. The pedal’s screen displays a connection symbol, and none of the buttons work. The pedal has been connected and updating for over three hours, and nothing has happened.
July 15, 2025 at 11:09 am #190929
Sorry for the issues you are having. It sounds like there was an issue with the update process. Please email support@eventideaudio.com and we can help you troubleshoot the issue there.
July 24, 2025 at 5:40 pm #191057
Hello there, I am unable to connect to control.
First box freezes on:
And or followed by unable to initialise.
Please assist,
Thank you.
G
July 24, 2025 at 5:56 pm #191058
Are you using Mac or Windows? Have you tried a different computer or USB cable?
August 21, 2025 at 6:32 pm #191699
New pedal I don’t own a MacBook or iMac desktop. I refused to buy another computer. I built my own keep it off the Internet
How do I update to get the control feature on my iPad
I’ve looked at the topics. I’ve looked at instructions. Follow them, and I am not able to open the app in my iPad. Can anybody help me with the missing link??
<p style=”text-align: left;”>Thank you</p>-
August 26, 2025 at 10:32 am #191727
Can you please be more specific with the issue you are having?
You will need to use a Mac or Windows computer to update the software on the pedal.
What do you mean “am not able to open the app in my iPad”? What exactly is happening after you’ve installed H90 Control on your iPad?
November 11, 2025 at 7:03 pm #193280
same problem here. with mac mini m4, try recovery mode. try usb c with nothing else inside the computer.
November 12, 2025 at 9:00 am #193286
Sorry to hear you are having issues. Please email support@eventideaudio.com and let us know what exactly happens when you try the recovery mode update. We can help you further there.
- The topic ‘Problem installing firmware h90’ is closed to new replies.
