Problem loading presets on H9
Home › Forums › Products › Stompboxes › Problem loading presets on H9
Viewing 4 reply threads
    • #114358
      tunisoifer
        I use the H9 with an external switch to manage preset changes. My problem is that with some algorithm’s (specially the pitchfuzz) the pedal bypasses for a few seconds when I increment or decrement presets. The same happens if i use midi. Any idea what can i do?
      • #147179
        tunisoifer
          I have news: with the app’s actualization is working better but i’m still havin a lot of trouble with the Pitchufzz algorithm. Does anybody can help me?
        • #147182
          stari
            I have the same issue – there’s a sudden drop on the pitchfuzz when I activate it. I will go from playing one sound, increment or decrement to the pitchfuzz, then activate it, and get that initial drop of sound.
          • #147276
            tunisoifer
              The pitchfuzz is working so bad and nobody is answering (i’ve also sent a mail with audio samples). What can I do?
            • #147278
                tunisoifer wrote:
                I use the H9 with an external switch to manage preset changes. My problem is that with some algorithm's (specially the pitchfuzz) the pedal bypasses for a few seconds when I increment or decrement presets. The same happens if i use midi. Any idea what can i do?
                It takes time to load a preset (usually well under a second). Big presets (like pitchfuzz) take longer than small ones. While the preset is loading, the unit is bypassed. Sorry about this, but it is the price for large complex presets.
                • #147284
                  tunisoifer
                    Ok, thanks for the answer. It would be usefull to warn this things. For me it’s unusable the Pitchfuzz in these conditions and i would have bought other algorithm if i knew it.
                    it would be useful to warn these things
