Problem updating to new H9 software
Home Forums Products Stompboxes Problem updating to new H9 software
    • #114275
      foxvernon
      I’ve tried several times to update to 5.4.1[7], but keep getting the following messages (see attachment). Any ideas? (Did search here but didn’t find an answer.)
      -Fox
    • #146830
      gkellum
      foxvernon wrote:
      I've tried several times to update to 5.4.1[7], but keep getting the following messages (see attachment). Any ideas? (Did search here but didn't find an answer.)
      Are you connecting to the H9 from an iOS device via Bluetooth?  We've seen these errors come up sometimes when other users tried to update that way.  If so, if you connect your H9 to a desktop computer using Bluetooth instead, you should be able to update that way.
      • #146833
        foxvernon
        Using bluetooth from my MacBook Pro did the trick. Thanks!
    • #149685
      cory508
      Hp not making any sound since i did the 5.4.1 update install. Help?
      • #149697
        bohan
        You may the restore factory settings, or install the update again. If it still doesn't work, please email support@eventide.com
