February 26, 2009 at 2:11 pm #106083
JustCause
MemberHi,
I have a problem.
After not using my eclipse for a couple of months the "internal checksum error" message appears every time I power up the unit.If I press a key it disappears and the unit works fine.
What should I do about this?
Thanks for your help.
Jorge
February 26, 2009 at 3:48 pm #118326
This could be a hardware fault, or an excess of cosmic rays in the neighborhood, but may just be a low battery in the unit.
First thing to try would be to change the battery.
February 28, 2009 at 4:06 pm #118337
JustCause
MemberHi Nick,
Thank you, that did help, the battery was completely flat.
However I just replaced the battery 10 months ago, what could have caused it to wear out that fast?Jorge
March 2, 2009 at 4:38 pm #129435
It may be related to how long the unit is powered up vs powered down, or it may imply that the battery backed ram is taking too much current.
If your unit is still under warranty you could consider sending it in for a checkup, but it would be easier and cheaper just to change the battery from time to time.
April 18, 2009 at 12:20 pm #129657
john316
MemberHow can you check on the status of the battery? I'm getting the Internal Checksum error" on boot up a few times now but not sure if it is the battery or a preset problem?
Thanks
Gerry
April 20, 2009 at 3:03 pm #129662
drooney
MemberHi John,
The best way to confirm the status of the battery is to use a multimeter and measure the voltage of the battery. If you find the voltage is anything below 2.8v then it is suggested to replace the battery with the same rating of the original, which is BR2330. These may be purchased at your local electronic store or from Eventide direct. Just contact support@eventide.com to order one.
To be sure that the cause isn't tied to a preset, it would be best to initialize the unit to clear out the internal memory. This action erases all user presets saved to the internal memory, so you may want to back up any user presets you have saved to the internal memory. With the Eclipse powered off, press and hold the 8 key and then power on
It will load processing code; then the OS version; then it will say ?Clear Internal Memory?? Select Yes. It will clear memory, initialize and then will load and display preset number 100 ?Mute Series?. This is to indicate the process is complete.
