Problem with PitchFactor
Home Forums Products Stompboxes Problem with PitchFactor
    • #174813
      alonkoval1
      In some settings that I’m using in the PitchFactor, the Pitch of the signal is by default not correct.
      for example – I press on bank 1a and the pitch is taking my signal and playing it in third (or any other random interval), and only when I press the flex button the pitch is going down to be unison as I originally set it to be.
      How can I fix this bug?
      thanks,
      Alon.
    • #174867
      Can you please be more specific with what Presets you are using? Some presets are intended to pitch shift your instrument to a different pitch, so it may be working correctly.
