Problem with reverse on TF
Home Forums Products Stompboxes Problem with reverse on TF
Viewing 3 reply threads
    • #106956
      grozeil
      I've encountered a problem with a preset of my TF. Here are the settings :
      Mix : 100
      Dly Mix : 10+10
      Dly time A : 1/4
      Dly time B : 9/16
      Fdback A : 19
      Fdback B : 70
      Xnob : 3ms
      Dmod : 5
      Speed : 0,05
      Filter : 0
      I use the TF with a Chapman Stick, so both inputs and outputs are used. It's simply full stereo.
      When I press the repeat switch, the signal is looped, but I just can't play over it, there's no signal passing through the TF. This problem seems to be only with this kind of delay, that doesn't happen with other delays type.
      Any ideas?
    • #120152
      IDeangelis
      Hello
      if you set Mix on 100% you only get to hear the wet part of the signal, not the dry.
      Try lowering Mix somewhere in between.
      best
      I
    • #120164
      grozeil
      So obvious… I'm feeling so stupid! Thanks for your answer BTW! Embarrassed Wink
    • #120180
      madeski
      i'm guessing it's cause you have the mix set to 100% wet. add some dry signal and see if you can hear what you play over the loop
