Home › Forums › Products › Stompboxes › Program Change H9
hello, I have an H9 plugged into my ableton live via midi.
all program change were working smoothly until it suddenly stopped, I did a hard reset to no avail.
what could’ve caused it?
thanks
Laima
Are you using the same settings in Live? Are you sure that your MIDI track is outputting to the H9? You must also make sure Live and the H9 are using the same MIDI channel.
