this could be simple but i cannot seem to get it. my h90 is second in line. my h9 is first. i use a boss es8 to make all changes. i set up the h9 no problem responds correctly every time, but that h90 has slots that dont match the pc number ive put in. this is about 4 out of 8 that wont work correctly. what gives?
It would make more sense to me if your mismatch count was 8 out of 8, but this might help: The H9 recognizes a PC range of 0-99. The H90 transmits / receives over a range of PC 1-100. System -> MIDI -> PC Offset =1.
ends up that it was the h9 in transmit and the offset. i had changed the offset several times, but with the h9 in xmit i didnt think it was the problem.
