Public Beta Release Latest
Home Forums Products Rackmount Public Beta Release Latest
    • #171738
      Hi all,
      We are happy to release H9000 Public Beta Firmware 2.1.10 and Emote 2.1.2!
      Please note that these are public beta releases and you may encounter some unforeseen bugs or issues. It is not recommended to update if you are in the middle of session work that relies on the current H9000 firmware.
      Please find the installers for Emote below, and use Emote to update your H9000’s firmware:
      macOS: https://etide.io/3GD6s
      Windows: https://etide.io/tTu9J
      Instructions for updating using Emote can be found here: https://cdn.eventideaudio.com/manuals/h9000/2.0/content/firmware.html
      A full list of new features and bug fixes can be found below:
      • New algorithms (sample rate limited to 48kHz):
        • Head Space: An authentic emulation of classic tape delays with adjustable playback heads, Wow and Flutter, Drive, Hiss, and Filter controls
        • Bouquet Delay: An emulation of analog delay pedals with two different flavors and a couple of modern tricks.
        • WeedWacker: Two stage, serial overdrive (distortion) effect. Both stages are identical. Each stage is reminiscent of a famous green overdrive used by your favorite blues/rock players of yore.
        • Even-Vibe: A faithful emulation of the classic Shin-ei Uni-Vibe™ in stereo!
        • WormHole: Mega-sized, tilting reverb with a Warp performance parameter
        • Polyphony: A low-latency, high quality polyphonic pitch shifter using Eventide’s new SIFT (Spectral Instantaneous Frequency Tracking) technology
        • PolyFlex: A fully polyphonic version of our classic, 2-voice PitchFlex algorithm, with a few added bonuses.
      • New general parameters for all algorithms
        • Kill Dry: removes the dry signal from the algorithm, effectively turning the algorithm’s mix control into a level control. Useful for wet/dry and aux send/return configurations where the H9000’s effect are in parallel to the dry signal.
        • Panning: Move the entire stereo image of an algorithm’s output to the left or right. Very useful when using multiple algorithm’s in parallel.
        • Solo: Bypass all other algorithms in the FX Chain. Useful when using FX Chains with many algorithms.
      • Add FX Chain Kill Dry
      • Add automatic input/output sensing to H9 algorithms
      • Fix mapping issue with certain algorithms
      • Fix bug causing H8000 looper algorithms to not work properly
      • Fix bug where front panel would not display the correct Session name or number in certain scenarios
      • Make factory Sessions and FX Chains not entirely uppercase
      • Add fan speed control. Toggle on for a lower fan speed. If the H9000 senses that it is operating at too high of a temperature, it will automatically change back to the higher fan speed.
      • Allow sigfiles with TAPKNOB to be imported. Users should update their sigfiles to use TAPERKNOB instead
      • Other small bug fixes
      Emote 2.1.2
      • General maintenance release for compatibility with H9000 Firmware v2.1.10
      • Apple Silicon (M1/M2) native support
      • Improve the “USB Audio Mute” warning. This is no longer a pop-up, and the warning will be displayed in red in the top right corner of Emote.
      • Fix bug to display correct session names when loading via the plug-in
      • Fix mapping display issue with certain algorithms
      • Fix mapping issue by adding scrollbar to mapping window when Emote display is small
      We hope you enjoy this update! Please create a new post in the rackmount forum or contact support@eventide.com with any questions or issues you may have.
    • #172489
      H9000 Public Beta Firmware 2.1.13 is now available. This firmware release is compatible with Emote 2.1.2, please use Emote to update your H9000’s firmware.
      • Add LFO retrigger to BouqetDelay
      • Fix H9 algorithm parameters mapping bug
      • Fix FX Chain mute/bypass bug
  • The topic ‘Public Beta Release Latest’ is closed to new replies.
