Home › Forums › Products › Stompboxes › Quadravox hotswitch
May 7, 2020 at 10:17 pm #115903birthofaheroParticipant
So I know the hotswitch is a “Learn” function but I’m trying to set a button on my midi controller to change one of the voices from a -4th to -3rd and back. Is this possible?
May 7, 2020 at 11:59 pm #154818birthofahero wrote:So I know the hotswitch is a "Learn" function but I'm trying to set a button on my midi controller to change one of the voices from a -4th to -3rd and back. Is this possible?
Yes. You can set the expression pedal (ribbon) mapping for that parameter from -4th to -3rd, and then assign the expression pedal (ribbon) to a CC message. Then you can use your MIDI controller to send that CC message to control this parameter.
May 8, 2020 at 12:05 am #154819birthofaheroParticipantbohan wrote:birthofahero wrote:So I know the hotswitch is a "Learn" function but I'm trying to set a button on my midi controller to change one of the voices from a -4th to -3rd and back. Is this possible?
What do you mean with the ribbon comment?
May 8, 2020 at 12:35 am #154820birthofaheroParticipantbohan wrote:birthofahero wrote:So I know the hotswitch is a “Learn” function but I’m trying to set a button on my midi controller to change one of the voices from a -4th to -3rd and back. Is this possible?
I think I understand what you mean, I can set the expression value aka hot knob to a CC# in the settings. That allows me to get to the expression settings set by the ribbon (in the app, I think this is what you mean) but what CC command would I send to get me back to the original settings? I think a simplier way to explain would be one CC command for toe up and one CC command for heel down.
May 8, 2020 at 1:40 am #154821birthofahero wrote:
But what CC command would I send to get me back to the original settings? I think a simplier way to explain would be one CC command for toe up and one CC command for heel down.
This should be the same CC. Let's say we assign the Expression Pedal mapping to CC 99. If you send CC 99 with value 0, the expression/ribbon goes to the heel position; if you send CC 99 with value 127, the expression/ribbon goes to the toe position.
May 8, 2020 at 4:12 pm #154823birthofaheroParticipantbohan wrote:birthofahero wrote:
Oh wow. How could I have missed something so obvious. Thanks for the reply!
