I have a question which is probably easy to answer, but which I can not solve.
I want to select a certain preset on my TimeFactor, based on a midi program change which it receives. I do not know how.
I use a GigRig G2. When I select a certain preset on the G2, a midi program change signal is send to the TimeFactor and the TimeFactor switches to a certain preset on the TimeFactor. However, I want the TimeFactor to switch to another TF preset. How can I get this done? How can I determine that if the TF receives program change 4, it has to select preset 2:1?
Thanks for your help!
Ed
