Questions about eclipse update
Home Forums Products Rackmount Questions about eclipse update
Viewing 9 reply threads
    • #105936
      Ruddy
       HI, this is the first time i've attempted a software update on my eclipse and i have a couple of questions.
       Do i need earlier software updates or does this new one cover all the previous updates. My eclipse is Version 3.0
      Also, do i need to unzip this downloaded update before i put it onto my compact flash card ?
      Thanks
    • #118051
      IDeangelis
       You can update Eclipse to the latest OS no matter which older version is running on your unit. No need to install versions "in between".
      Yes the files need to be unzipped and directly copied to a CFCard; don't create any folder…just copy them straight to the card.
      best
      I
    • #118052
      Ruddy
       Okay! Thanks a lot for the quick response.
    • #118053
      Ruddy
       Is it unusual for "loading romprog.exe from card" to be on the screen for a long time ?
       It's been on for about 20 minutes so far.
    • #129167
       You are correct to be concerned – it should disappear almost immediately.
      The problem is probably the card you are using. Make sure it is less than 4G and is formatted as FAT, not FAT32.
      A new card of less than 1G will probably be FAT. On a PC, you can specify the format type when formatting.
    • #129168
      Ruddy
       Hi, yeah it was FAT32, not FA. Thanks it's worked straight away now.
      It looks like it's finished now. although im a bit unsure that everything's ok .
      it says:
       "Evenitde software update utility V2.03 (?)
      Programming completed. Cycle power"
      Thanks
    • #129169
       Sounds like you're good to go. Give it a try ..
    • #129170
      Ruddy
       Yeah, everything's fine. Thanks for the help!
    • #118145
      balseiro2007
      hi, i got a sandisk ultra II cf card 2GB, and i can't upgrade to 3.51, do i have the right card?…thanks and if you know a way to upgrade please do it in detail (im not a computer person)
    • #129229
       You don't say why you can't upgrade which makes it hard to help you.
      However, a 2GB can be used, but it has to be set up right. There are two "formats" (ways the card can be set up) that might be used. One is called FAT, and is OK. The other is FAT32, which Eclipse can't use at this time.
      You must make sure that your card is setup as FAT. On Windows, this is an option on formatting the card.
      You should tryand find a local computer person to help you. Otherwise you can order a card from Eventide.
