Questions on Orville and H8000FW
Home › Forums › Products › Rackmount › Questions on Orville and H8000FW
Viewing 4 reply threads
    • #111987
      – In the Orville manual it says that the foot pedal jacks 1 & 2 can accept control voltages.. Is this true for both machines and in case what is the input voltage range?
      – If I assign a controller to a global parameter via pressing the Select key (e.g. input level), will it be store it as part of the preset or will it be lost?
      – Which module and initiallizations shall I use in Vsig if I want to 'hardwire' a specific midi continous controller in the preset?
      Thanks
    • #126802
        The control voltage input range is 0-5V. This applies to both Orville and H8000 family
        global parameters – I believe they are stored separately, not as part of the preset.
        midi continuous controller in Vsig – either:
        1) click on a knob output, then MIDI/add remote
        or
        2) use the EXTCONTROL module.
      • #126806
        Ok.. Regarding:
        1) The Midi – Add Midi controller : this is for testing midi control in a patch that is set up for midicontrol only, and not for assigning a midicontoroller?
        2) Using the EXTCONTROL module, it's easiest to allways set Spec1 field to 0, then load program to the Harmonizer and then set up for the right midicontroller on the H8000FW screens?
      • #137430
          1) Yes. Note that MIDI/Add remote does add a controller.
          2) When using EXTCONTROL, this would be easiest.
        • #137431
          Thanks.
          Which modules can I use in vsig to make use of the System Tempo and System Timer for automatic sync to the midi tempo? E.g. to get the t_delaytime parameter in a delay preset, for example.
