Hello Crew
I was just wondering what the control signal sampling rate was in the H8000,
And if this rate is a subdivision of the Master Clock……?
In which case I guess, higher sampling rates = finer control signal rates??
Also….Is there a way for me to adjust the control signal rate directly? (I know I can use audio rates)
On some of my equipment I can set control rates and sampling rates independently (which is very very handy! 🙂
Say I have a patch where realtime updates are not too important I'll use a "set & forget" control sampling rate of, maybe 25Hz. Whereas if the patch IS the instrument I'll use a rate of maybe 3200Hz.
Anyway….
I'm getting really into vSigX / H8000
It's more fun every day!!
-C
