May 1, 2016 at 3:37 am #113431shaunp1982Member
Hi Everyone;
I’m looking to rackmount install my newly purchased H8000FW using the following product:
http://www.samsontech.com/samson/products/accessories/racks/srk8/
From reading the H8000FW operating manual, it sounds like the unit can be adequately supported solely from the front panel (ie ‘rack ears’) using the four bolts that were supplied within the packaging – is this correct?
Is it possible/better to use some kind of 1U rack shelf beneath the H8000FW, which presumably could provide more ‘uniformly distributed’ support over its base area rather than ‘cantilevering’ it from one end?
Obviously, given the value of the H8000FW, I’d prefer to avoid taking any unnecessary risk(s)…
Thanks in advance and much appreciated, Shaun
May 1, 2016 at 12:50 pm #143252
hi Shaun
Hope you are enjoying your H8000. The front panel bolts are ok for a stationary installation, but you should add back support if the rack is going to be moved. Also, try and allow a bit of space around it for cooling.
May 2, 2016 at 6:12 pm #143264shaunp1982Member
Thanks for the quick response, Nick.
Any suggestions/recommendations on how to provide ‘back support’ – would this typically be accomplished using some sort of proprietary product, or just whatever DIY solution works for the specific application?
Thanks again, Shaun
May 2, 2016 at 10:27 pm #143266shaunp1982 wrote:
Any suggestions/recommendations on how to provide 'back support' – would this typically be accomplished using some sort of proprietary product, or just whatever DIY solution works for the specific application?
A DIY solution would be indicated. If there is room, I'd stick a 2×4 under the back.
May 3, 2016 at 12:17 am #143268shaunp1982Member
Thanks Nick!
