Rackmount support
Home Forums Products Rackmount Rackmount support
    • #105789
      Page 53 of the H8000FW Manual has a strong recommendation to support the rear of the unit in a rackcase that will be transported.
      I'm considering a tall case w/ casters and am wondering what any of you are using for rear support of this heavy unit ?
      Thanks
      -Richard M
    • #117829
      Hello Richard,
      I just bought 4 small angle brackets from a hadware store, stuck some adhesive foam on the surfaces that would touch the H8000, and screwed them right into the plywood.  I positioned them above and below the unit and tucked them in so that the foam was slightly compressed.  Cheap, quick and effective!
      Cheers,
      ben
    • #117830
      Thanks, Ben… I just wasn't sure how much room there would be in the rack-case I  ordered from PearsonCases.
      The case is plywood and brackets can be screwed in easily.
      Hope you will take a look at David Teren's new Eventide Harmonizers Facebook Group…. see you there !
      -Richard M.
