- This topic has 9 replies, 7 voices, and was last updated 10 months ago by
Eventide Staff.
January 29, 2024 at 5:42 am #177777
In first i want to say thank you for a such incredible plugin!
Please consider to add Reverse type as global to each type of “Behaviour”
also would be great to see addition flanger/phaser in ‘sound stage’ section and ability to apply it not only to feedback loop but as well as to main signal.
Anyway thank you!
January 29, 2024 at 12:19 pm #177784
Thank you! And thanks for the feature requests! I’ll add them to our list.
Dan
February 11, 2024 at 5:15 pm #178106
If you can find a way to decrease the CPULoad on all of the Newfangled Audio plugins, it would be greatly appreciated.
In Studio One, with just 1 instance of Recirculate, I was getting CPU Usage levels of 20- 22% CPU.
I was told by a Newfangled Audio fan, on Youtube, he was Running 8 instances with No problem, and I should get a new Computer.
I have a Dell / Alienware R12 liquid cooled with gen 11 Intel i7-11700K 3600Ghz and 128 GB Ram 3600 Ghz.
Have I missed Something, is my computer old, tired and out of date to run these plugins?
February 13, 2024 at 4:14 pm #178176
Hi Whats, can you do me a favor and check to see how many instances of Recirculate you can get on a channel? I have had instances of people reporting 20% CPU, but then they can put 15 of them on a channel without a problem. If you really can’t get more than 5 on a channel please contact support at Newfangled Audio and we should talk.
Thanks,
Dan
March 26, 2024 at 10:31 pm #180270
I have the same problem on a powerful 8 core intel iMac – Recirculate overwhelms the CPU – shoots uo to 50% usage – None of my other plugins cause system overloads – just this one
April 2, 2024 at 9:09 am #180416
The problem is that it’s a victim of its own brilliance – it sounds so good that I want to add it to everything and it causes my system to crash like no other plugin I’ve ever used. Is it fully Mac intel compatible? Is there a less juicy update coming? Before adding more features it would be good if it operated more reliably as is. It would be my favourite plugin if it could be used without causing a horror show of issues
April 2, 2024 at 3:29 pm #180427
Hi Vibrolux1,
We haven’t had any reports of crashes at all. Some reports of high CPU usage, but no other problems. Can you contact support at newfangled audio dot com and let me know which specific issues you’re having? And maybe a bit about your system (Mac/Windows, VST/VST3/AU/AAX, which DAW)? If you let me know about any specific issues and steps to reproduce I’m sure we can get you sorted.
Thanks,
Dan
April 12, 2024 at 10:57 am #180940
Reply to Dan
I did all that but heard nothing back. Such a shame because I love what it can do – but frankly dare not use it until it’s more stable
November 3, 2025 at 5:22 am #193093
FYI same problem with the recently introduced Temperance Lite. Mac Studio M2, AU plugin. As soon as it’s placed on a channel it consumes about 20% CPU of one core. I’m guessing whatever causes it is part of Eventide’s standard code rather than just a specific plugin. Shame that you didn’t hear back from support. Like you, I like the look of the plugin but I’m not going to risk it on my projects.
November 3, 2025 at 5:22 pm #193114
Sorry to hear you are hear you are having issues. You can try Eco mod in Temperance Lite by clicking the leaf corner in the upper right corner to reduce the CPU load.
