Recirculate Not Listed in Studio One 5
Home › Forums › Products › Plug-Ins › Recirculate Not Listed in Studio One 5
    • #178270
      jonnyrebel
        I just purchased Recirculate and it’s not showing up in Studio One 5. It is showing up in Cakewalk by BandLab and Sonar Platinum.
        Please assist!
        Thanks,
        Jon
      • #178271
          Below are some basic troubleshoot steps you can try:
          *Note that Studio One will not display the VST2 version of a plug-in if the VST3 version of the plug-in is installed. If you’d like to use VST2, you must uninstall the VST3 version of your plug-in.
          • Open Studio One, go to your VST preferences, and make sure “Scan at Startup” is checked.
          • Also click “Reset Blacklist” in the VST preferences, and then restart Studio One.
          • If the above steps don’t work the user can try moving the following folder to the desktop, and then reopening Studio One:
            • /Users/<username>/Library/Application\ Support/PreSonus Software/Studio One <version>/x64
            • C:\Users\<username>\AppData\Roaming\PreSonus\Studio One <version>\x64
        • #178316
          jonnyrebel
            Thanks for the quick reply. I already had the “Scan at Startup” and “Reset Blacklist” checked, but moving the \AppData\Roaming\PreSonus\Studio One\x64 folder to the desktop fixed the issue. The folder,  “/Users/<username>/Library/Application\ Support/PreSonus Software/Studio One <version>/x64” doesn’t exist. I preserved the old \AppData\Roaming\PreSonus\Studio One\x64 folder if you would like to do forensic analysis, otherwise, I’ll delete it.
            Thanks for your help!
            Jon
