Home › Forums › Products › Rackmount › Registration pbm
i'm trying to register my DSP7000 but can't find any number on the back panel.
When i try to use the Hardware ID found in SETUP/Service/information i got an "invalid serial number" message.
What should i do ?
Greg
The serial number is usually on a label towards the rear of the left hand side.
If for some reason it is not there or is damaged, you should contact support@eventide.com with as much information about the unit as you can muster.
Thanks for answering.
Had time to unrack today and found that number.
I guess i was so excited about racking and playing with it that i didn't pay attention to that label !
