Rename Modfactor presets through Factor Lib…?
Home Forums Products Stompboxes Rename Modfactor presets through Factor Lib…?
    • #111817
      wallofsound
      What's the simplest way to rename the prests on my Modfactor? I would like to do it through the Factor Lib… THANK YOU!!!!!
    • #126418
      gkellum
      wallofsound:
      The simplest way to rename presets on your ModFactor would be to use H9 Control. If you go to the Preset List screen in H9 Control, you can click on your ModFactor to look at all of its presets, and if you click on one of your presets to open it up, you can double click on the button representing the preset to rename it.
    • #126423
      wallofsound
      It woooorrrrks????????
      Thank you!
