repair vs. replacement
Home Forums Products Rackmount repair vs. replacement
    • #106042
      danharr
       Hi-
      I have an old H3000S, which seems to have died tonight.  I'm fond of it but admit that I really only use the micropitchshift program…  I'm trying to decide whether to pay to have it repaired or to just bite the bullet and get an Eclipse.  I can't afford the more expensive units and wonder if there is any aspect of the old H3000 the Eclipse doesn't do better.  If I replace the 3000 with the Eclipse will I be missing anything?
      Thanks,
      Dan
    • #118229
      IDeangelis
       HI Dan
      Eclipse covers almost all H3000 fx. Sure enough you'll get Micropitch covered.
      In addition, there's a lot of other fx in it that the H3000 can't do at all, including multivoice chorus, flanger, looping, up to 8 voice pitch shifting, Tap Tempo delays/lfo rate/verb decay/true multi-fx capabilities, MUCH better reverbs….and more.
      Much faster presets switching/24 bit-96KHz/unlimited presets storage on CFCards/balanced+unblanced I/O/digital I/O/…and the sound IS Eventide!
      all the best
      I
