resetting the timefactor
Home Forums Products Stompboxes resetting the timefactor
Viewing 5 reply threads
    • #105658
      This is my first post. The timefactor I have is still trying to wrestle my sounds so I was wondering if any of you could tell me how to reset the delay to the factory sounds. Also I could use a link to the updates because I have vista and nothing seems to want to read the usb plug in
      help?
      ty
      KOn
    • #117668
      achaput
        To reset Eventide Stompboxes to their original Factory Presets and default settings, power up while holding down both the middle Footswitch and the Encoder button.
        Warning: This will erase any user Presets you have saved and will return System settings to factory defaults.
      • #124846
        What is the encoder button??
      • #135684
        gkellum
          It's the one that you use to select algorithms.  It spins around and can also be pressed…
        • #135685
          Thanks! got it. now it doesnt work at all… My timefactor started scrolling like mad thru numbers…. 102.1.42     103.1.42
          for 2 hours it did this. So frustrated at this point i'm thinking of shooting my timefactor
        • #135686
          gkellum
            You should get in touch with support@eventide.com about your problem.  That obviously isn't normal behavior.
