Home › Forums › Products › Vsig and Preset Development › Reverb_D delay clarification
April 16, 2020 at 4:39 pm #115868Hello everyone,I have a few questions on Reverb_D:How do the delays work? Example:L R L R10 20 30 40Is that absolute, or is 30 actually 30+10, and 40, 40+20?If absolute, then on Italos ‘plate’:75.7 83.1 90.3 93.9 94.3 78.6 108.8 114.0 157.2 134.2 141.9 123.1Could also be:75.7 78.6 90.3 83.1 94.3 93.9 108.8 114.0 141.9 123.1 157.2 134.2Note: I just sorted L/R channels.Also,Does the first delay matter? Can it be set to 0 and use ‘predelay’ to shift delays over? Is it customary to use something over 5, 10, 15?Any tips to simulate plates, halls, rooms, etc? Note: I know diffusion has a lot to do with that.
April 16, 2020 at 4:46 pm #154607
Hi eventidesurf,
The Reverb_D module uses what is often called a Feedback Delay Network (FDN) structure. In this structure the delays aren't left and right, but they're all in parallel with a large feedback matrix which controls how they're fed back. If you're interested in a good introduction to FDNs you can check out Julius O Smith's page on the topic (https://ccrma.stanford.edu/~jos/pasp/FDN_Reverberation.html)
So the delays aren't really left and right, and because of the matrix the order does matter. You can obviously sort the delays that way, and the reverb will probably sound similar, but different.
A full reverb would usually be built by adding a multitap delay module, like multitap or easytaps to simulate early reflections, followed by some diffusors, like the diffusor module, then a Reverb_D, then maybe some EQs for the output. Setting the delays lengths and feedback values tends to be a dark art, and honestly my approach is usually just to fiddle with it until it sounds good.
April 16, 2020 at 4:47 pm #154608
You can also look at the existing Reverb programs in the H9000 and look at what was done for a primer.
April 16, 2020 at 6:27 pm #154610DGillespie wrote:
Hi eventidesurf,
The Reverb_D module uses what is often called a Feedback Delay Network (FDN) structure. In this structure the delays aren’t left and right, but they’re all in parallel with a large feedback matrix which controls how they’re fed back. If you’re interested in a good introduction to FDNs you can check out Julius O Smith’s page on the topic (https://ccrma.stanford.edu/~jos/pasp/FDN_Reverberation.html)
So the delays aren’t really left and right, and because of the matrix the order does matter. You can obviously sort the delays that way, and the reverb will probably sound similar, but different.
I was afraid it was going to be more complicated. Italo’s plate and chamber seem to be a bit vibey, even if I reduce the first delay down to 15 and shift the rest of the delays down evenly, then increase rsize to compensate. If you use more consistent delays, such as one of the other presets from Italo (I’m using H8000FW btw):
15.0 22.0 30.0 39.0 50.0 60.0 78.0 90.0 120.0 135.0 158.0 166.0The reverb sounds smoother, but somewhat less dimensional, less bloom.I’m using stereo taps to simulate ERs. Unfortunately the other modules were buggy when I tried them. I do use an EQ also. Thanks for the link!
