Rocktron All Access controller
Home Forums Products Rackmount Rocktron All Access controller
    • #105765
      rik
        HI,
        I was reading the manual on midi, and I didnt see anything about Title transfers. Will the eclipse do title transfer to the all access controller? This would be nice since I am used to this feature!
        Also, seems things are 1 off for the program change control. ??
        Thanks in advance for any information regarding the all access.
      • #117734
         Hi Rik
        being an Eventide forum you will find Eventide products information than other products'.
        The Eclipse doesn't do title transfer. The 1_off is a common aspect of MIDI protocol which legally can count 0>127 or 1 >128. Very likely the All Access has a system setting that allows to switch between the 2 counting ranges. Otherwise you have to live with that.
        all the best
        i
      • #117735
        simeon
          you could always use a midi map to realign your program numbers…i think midi map number 2 is set up for controllers which are 1 digit out. go setup > maps.
          sim
